Re: M Throttle lever adjustment
Posted by Wild Horses on May 04, 2004 at 08:25:59 from (216.51.163.251):
In Reply to: M Throttle lever adjustment posted by jamie on May 03, 2004 at 10:45:09:
The play between the governor lever and the throttle is caused by two opposed springs in the linkage at the arm that is up by the valve cover. This allows a little movement of both throttle and governor against the other's position. As for the RPM limit, I'd check the stop bolt inside the governor first. There is a bolt in the front arm inside the governor that comes against the housing, stopping it from opening farther. This was used to set the WOT. Very few M's will stay at WOT. Most will back off slightly. Are you using a friction disk or toothed throttle? The friction disk may need changed out or the spring tightened down with a washer. With a weak spring, the tractor would often bounce and jostle the throttle causing it to shut down. Aside for that, I'd also check the governor spring. It could have a stiffer spring that is pulling against the throttle.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
