350 ut fan in the radiator again don't know why
Posted by mark on May 04, 2004 at 17:41:15 from (206.216.195.114):
I have a 350 ut and for some reason the fan went in to the radiator( cut the bottom tank right along the top next to the veins) .I can not find nothing wrong with the fan all I could see is it looked liked the fan blades where bent out.
This happen one other time when the bearings in the fan hub went bad .but that is not the case this time.
Does any one have a ideal what may be cuseing this . I would like to stop this from happing again .This is a costly fix. radiator are not cheap to buy or fix.
At lest it happen now and not when I was in the field with it.
Post a Followup
: Re: 350 ut fan in the radiator again don't know why
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
