Re: Re: Re: Re: 560 is hard to shift to neutral af
Posted by R. Smith on May 04, 2004 at 19:45:39 from (64.232.242.239):
In Reply to: Re: Re: Re: 560 is hard to shift to neutral after posted by Hugh MacKay on May 04, 2004 at 02:52:16:
Hugh, I've read through a few of the other question/answers dealing with other shifting problems and notice that you've helped others.
Good deal. If I understand it correctly, the torque shaft also physically disengages some sort of clutch in the TA unit? Since my shaft moves freely and only stops moving when the shaft lever hits on the tractor... Would any adjustment here do any good? Hardly seems to me as if it would but I've certainly been wrong before. Unless this short lever on the shaft is in the wrong position somehow?
Post a Followup
: Re: Re: Re: Re: Re: 560 is hard to shift to neutral af
