Re: Adding safety switch to H/300
Posted by williamf on May 05, 2004 at 03:26:53 from (66.82.9.69):
In Reply to: Adding safety switch to H/300 posted by 26Red on May 04, 2004 at 14:11:38:
I'm not sure how the 300 is wired, but my H has the push button starter on the side of the steering post. It would be fairly simple to add another button in the cable, so that both would have to be closed for power to get to the starter. The second button could be mounted so that fully depressing the clutch pedal made it. I've got a Ford with a switch in the transmission that requires it to be not just in neutral but with the shifter held in the exactly correct position, with a little side pressure. Useless, as the only practical way to use it is to straight wire past it.
Wm
Post a Followup
: Re: Re: Adding safety switch to H/300
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
