Re: Main Bearings in H
Posted by Theman on May 05, 2004 at 08:42:26 from (65.248.77.5):
In Reply to: Main Bearings in H posted by BB on May 04, 2004 at 18:53:32:
To answer your second question: The bearings can indeed be changed without splitting the tractor or removing the crankshaft. Parts to have on hand are the bearings, safety wire, pan gasket (and sealer if preferred), and you favorite assembly lube (STP, Assembly Oil, Motor Oil, etc.). Take out the spark plugs as you will be turning the engine over by hand. Remove the oil pan. Remove the rear main access plate (3 screws) and the plate under the bearing cap (3 screws). Replace only one bearing at a time so the crankshaft isn't damaged. To remove the bearing shell that is above the crank journal in the block, use a cotter pin with the two sides bent into the shape of an italic "T" - when you place it in the crankshaft oil hole, you will understand. Make sure the bends are sharp enough to only contact the bearing shell. Place the loop of the cotter pin in the crankshaft oil hole (a dab of grease will help it stay put) and rotate the crankshaft carefully in the direction that will roll the shell out away from the locator notch. Oil up the new shell and replace it in the block in the reverse order. Torque the cap bolts to 75 ft.-lbs. and check for binding. There should not be any. If OK, proceed to the next bearing. If you think it would be easier for you, it is OK to drop the oil pump (2 screws) as it doesn't affect ignition timing like some car engines. The final step is to verify the bolt torque and wire them up.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
