364 trans/diff fluid change - where is the other d
Posted by Greg on May 05, 2004 at 10:24:32 from (4.227.123.225):
I can't find the drain plug at the rear diff of my 364. I posted this some time ago and was told it is in the very rear near the PTO shaft but I don't see it. Can someone tell me again where to look exactly? I find 2 drain plugs under the shifter area but I sure need to find the one that drains the rear diff. Sorry, I searched for my previous post but couldn't find it.
Post a Followup
: Re: 364 trans/diff fluid change - where is the other d
