Gasket Air Leak 424?
Posted by Spence on May 05, 2004 at 16:43:23 from (206.172.137.3):
I have a 1/8inch sized head gasket air leak just under and to the rear of the 3rd glowplug from the front of the engine (BD154).
It doesn't seem to cause power loss, or engine startup problems. Engine runs smooth and has lots of power.
Is this a major headache waiting to happen?. I tried to silicon it, but the pressure pushes it out. If there were any bolts near it, I could jimmy up an angle iron type cover plate with a "goop" gasket, but no bolts are handy near it.
Thanks.
Post a Followup
: Re: Gasket Air Leak 424?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
