Re: 1942 Farmall M torque amplifier
Posted by Hugh MacKay on May 05, 2004 at 17:02:30 from (209.226.247.162):
In Reply to: 1942 Farmall M torque amplifier posted by Jamie Stratton on May 05, 2004 at 16:30:05:
Jamie: You may as well buy a SMTA as everything from the back of the engine to the drawbar is different.
Post a Followup
: Re: Re: 1942 Farmall M torque amplifier
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
