Re: Need torque specs for Farmall A cylinder head.
Posted by Randy in NE on May 05, 2004 at 18:18:41 from (216.58.237.20):
In Reply to: Need torque specs for Farmall A cylinder head. posted by Tom Williams III on May 05, 2004 at 16:15:33:
The head bolts get torqued to 80 ft-lbs. Work from the center out towards both ends at the same time. You may start at 40 ft-lbs, work your way through all of the bolts, and then increment in 10 lb increments. After you get it all together you will need to run the engine long enough to get it up to operating temperature and then re-torque the head bolts. This means pulling the rocker arm off, torqueing the head bolts, replacing the rocker arms, and then setting the valves again.
Post a Followup
: Re: Re: Need torque specs for Farmall A cylinder head.
