Re: Re: Re: Re: mcormick w 4 ele ?
Posted by 49 Cubber! on May 07, 2004 at 13:59:13 from (206.74.216.123):
In Reply to: Re: Re: Re: mcormick w 4 ele ? posted by Farmallkid on May 07, 2004 at 13:47:47:
Even if your on 12 volt,get the biggest cables you can,0 or 1 gauge if you can find it works well for me.Some use welding cable.
Post a Followup
: Re: Re: Re: Re: Re: mcormick w 4 ele ?
