Re: 460U gas line, throttle spring, air precleaner
Posted by RPM on May 08, 2004 at 09:42:33 from (209.152.115.185):
In Reply to: 460U gas line, throttle spring, air precleaner posted by doug stockman on May 08, 2004 at 03:25:28:
The gas line, get a steel brake line at any auto parts store, cut the flares and remove the nuts, get 2 special nuts at CNH dealer, part 222-503, these have a groove that breaks off end when you install the line and into original fittings for the depth by pushing line into carb fitting and same for fuel trap under tank, this will crimp itself onto line, then you can remove line again later and ends should be reusable. The linkage for throttle is going to be tougher, these parts no longer available except spring and ball end joint, junk yard only hope. 460-560 never had any paper air filter of any kind when built either on top or the main lower filter that was oil bath.
Post a Followup
: Re: Re: 460U gas line, throttle spring, air precleaner
