Re: Head Gasket Problem?
Posted by Bernard le mécano on May 08, 2004 at 16:38:04 from (207.134.173.242):
In Reply to: Head Gasket Problem? posted by UpHere on May 06, 2004 at 07:23:02:
Hi, if you have water or anti-freeze in the oil pan, it's a leak to the cylinder sleeve O-rings. Don't run an engine with some anti-freeze in the oil, bad damage to the crankshaft!!!
Bernard le mécano Québec Canada
Post a Followup
: Re: Re: Head Gasket Problem?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
