Re: Re: SuperMTAD
Posted by ChadS on May 09, 2004 at 08:17:48 from (66.228.96.154):
In Reply to: Re: SuperMTAD posted by paul on May 09, 2004 at 06:56:28:
To the best of my knowledge, ther is 2 different types of hubs that they used on the M-450. they had 3 differnt styles of rims as well, you had the old style, which had the singe raised center, then the 3 step rims for later model tractors, then the style like on the late super M, MTA 400,and 450. The latest style only has 1 driving lug, and a nut to adapt the rim to the hub, and the rim has a raised "ring" around them in 2 or 3 different locations on the rim, so you can move the tires in and out with out having to mess with the hub on the axle. Hope this helps, I will have another look at the MDTA again, thanks! CadS
Post a Followup
: Re: Re: Re: SuperMTAD
