Re: Re: Re: Re: Re: Farmall M
Posted by Wardner on May 10, 2004 at 00:12:39 from (4.138.240.19):
In Reply to: Re: Re: Re: Re: Farmall M posted by Jamie Stratton on May 09, 2004 at 17:35:29:
The tin, if installed, is on the bottom. You need to get on your back and look up. Your mid- tractor hydraulic system (Liftall) is probably only used as a reservoir for the ignition drive live pump. If that is the case don't use 30 weight. Use Hy-Tran or hydraulic oil. Heavy weight oil in the live pump might damage your camshaft gear in cold temperatures if the hydraulics are being used to lift something like a snowplow.
Post a Followup
: Re: Re: Re: Re: Re: Re: Farmall M
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
