49 h tranny problems?????? long....
Posted by jason r on May 10, 2004 at 06:35:55 from (65.204.92.51):
hi i just got a 49 h and it runs really well but it jumps out
of 5th over real bumpy ground. it will stay in while
going down the road without holding it in. all of the
other gears work well with minimal noise. i am
wondering if it is related to this problem....the bearing in
the shaft above the one running from the tranny to the
pump (drive shaft) in the tranny case seems to make
noise and also is leaking a bit of transmission fluid. can
this be replace without splitting the tractor? would that
be causing the 5th gear to jump since it is direct drive?
how much do these bearings usually cost. it doesn't
grind at all but it sounds "loose" and the shaft doesnt
seem to wiggle much. the sound goes away with the
clutch engaged. hope i got all the info right! thanks!!!
Post a Followup
: Re: 49 h tranny problems?????? long....
