Re: installing 460 cylinder liners
Posted by the tractor vet on May 10, 2004 at 19:39:16 from (216.196.13.12):
In Reply to: installing 460 cylinder liners posted by TimS on May 10, 2004 at 15:18:36:
Mike the flange and depth mike the counter bore and shim to spec. Make sure that they are press fit and not slip fit , yea i know that perfect circel sayes that you can slip fit them it will be fine , yea sure then you can pull what is left of the sleave from the rod after it breaks the lip off and is sucked down to the crank.
Post a Followup
: Re: Re: installing 460 cylinder liners
