Re: 756 WITH FAST HITCH
Posted by r4etired on May 10, 2004 at 19:54:15 from (205.188.116.213):
In Reply to: 756 WITH FAST HITCH posted by G MAN RED on May 10, 2004 at 14:22:53:
My set has a hinge in the middle with a pin to change the spacing, they sure make hooking to an implement a lot easier. just pull the pins and they will spread to go over the end . I have the only set like them I have ever seen. I use my 2pt draw bar, I made some open top adapters and welded them to the draw bar,now I just go under and lift. I fabricated a slide over lock so you can use down pressure,
Post a Followup
: Re: Re: 756 WITH FAST HITCH
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
