Re: 300/350 rods
Posted by MPJ on May 11, 2004 at 18:00:14 from (205.188.116.213):
In Reply to: 300/350 rods posted by JB on May 11, 2004 at 15:44:21:
No. Early 300 Rods have a larger wrist pin. Later ones are the same. The later rods and the 350 measure 7/8" You can get adapter bushings and have them fit by a machine shop if you have the older larger rods.
Post a Followup
: Re: Re: 300/350 rods
