Re: Re: super c rod and main bearings
Posted by G Cole on May 12, 2004 at 03:25:43 from (209.142.163.143):
In Reply to: Re: super c rod and main bearings posted by Ed on May 11, 2004 at 20:08:54:
Thanks. Any idea how much labor or time it will take for repair? Does it have to be split? Thanks
Post a Followup
: Re: Re: Re: super c rod and main bearings
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
