Farmall Tractors Discussion Board
Re: Re: Re: Re: H Heads
Posted by jakee on October 26, 1999 at 20:13:44 from (205.188.197.23):
In Reply to: Re: Re: Re: H Heads posted by Tom H on October 26, 1999 at 19:02:15:
at a good head shop will charge a bunch to make a head work right, and show you the result,s on a flow chart, we have also used a 300 gas head and with a .100 cut you will have about 103cc,s,one thing i found is if you advance the cam 1 tooth it will give it a bunch of bottom end,also unshroud the intake valve some and it will help flow
Post a Followup
: Re: Re: Re: Re: Re: H Heads
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
