Re: farmall 200 runs on choke only
Posted by scruffy on May 12, 2004 at 19:32:06 from (64.228.43.91):
In Reply to: farmall 200 runs on choke only posted by Rock on May 11, 2004 at 20:18:25:
I had similar trouble, it would run great then require full choke and run like $!##. Had a hole in the float. Not easy to solder,just when you get the lead melted, the heated air inside of the float would expand and pop a hole in it.. You must place the float in cool water after the solder is flowing, it gets sucked in and hardens. I got this tractor from a wrecker 'cause everyone had given up on it.
Post a Followup
: Re: Re: farmall 200 runs on choke only
