Farmall Tractors Discussion Board
Re: Re: Re: 340 that shoots flames out exhaust!!!!!!!!!!!!!!!!!!!!!
Posted by Charlie V AKA F20II on October 26, 1999 at 21:24:24 from (207.202.174.203):
In Reply to: Re: Re: 340 that shoots flames out exhaust!!!!!!!!!!!!!!!!!!!!! posted by Russ on October 26, 1999 at 18:19:03:
I agree with Red and Aaron, you have a stuck value, I have a 340D and have never seen my stack shot flames' nor turn red, even after plowing for 5 hours or more :-) The only other thing I can say is if you have " D " they may have a larger button in the injector pump, I suggest changing it back to normal. If it's gas they may have put bigger jets in the carb, but it shouldn't run well at lower speeds if they have done this. Again I suggest going back to the nomal jets and setting if this is true
Post a Followup
: Re: Re: Re: Re: 340 that shoots flames out exhaust!!!!!!!!!!!!!!!!!!!!!
