Farmall Tractors Discussion Board
Re: Re: Re: Charlynn pump on pto has leaking seal.
Posted by Farmer Bob on October 26, 1999 at 22:10:08 from (207.227.187.76):
In Reply to: Re: Re: Charlynn pump on pto has leaking seal. posted by Rod Hergott on October 26, 1999 at 21:32:01:
Rod, The slide hammer puller is the same thing used in autobody shops and refered to as "slide-hammer" dent puller. They are about 16" long with a screwdriver looking handle with about a 3/8"-7/16" shaft over which slides the "hammer" (about a 4" long, 1-3/4" diameter heavy sleeve with grooves in it for grip). The far end has a chuck looking thing that holds a heavy gauge sheet metal screw. You drill a pilot hole in the old seal about two drill sizes smaller than the screw in the puller (I'd drill about 3 or 4 at 12/3/6/9 o'clock) then screw the pullers screw into the pilot hole down to the chuck. Hang onto the handle with one hand and slide the "hammer" hard against the handle with the other hand. You should see the old seal break loose after a few "whacks". Keep doing this around the seal until you can just pull it out of the housing. Pullers are sold at most auto parts places and Sears. Good luck with it. FB
Post a Followup
: Re: Re: Re: Re: Charlynn pump on pto has leaking seal.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
