Re: switching from generator to alternator
Posted by Dan on May 14, 2004 at 07:22:30 from (12.160.171.229):
In Reply to: switching from generator to alternator posted by casey on May 14, 2004 at 06:23:29:
I switched 2 tractors from generator to alternator and 6 to 12 volt. I used the Delco 3 wire alternator with internal regulator. There is an excellent diagram done by Bob M on the archives of this forum. I don't know about wiring on the external regulator type. With so many of the Delco ones around in wrecking yards and all it easy to find. Are you also converting from 6 to 12 volt?
Post a Followup
: Re: Re: switching from generator to alternator
