Re: Cub Cadet 107 Lift Handle?
Posted by Harold H on May 14, 2004 at 14:03:46 from (66.6.180.146):
In Reply to: Cub Cadet 107 Lift Handle? posted by Kenneth Fass on May 14, 2004 at 08:33:15:
The little button on the front of your handle is stuck in. Work it out with a good pair of vice grips and your latching rod and button should spring up. After you get the little button on the front of the handle out, you can screw off the top button and put some oil down the hole to lubricate the rod and be sure the spring is still good.
Harold H
Post a Followup
: Re: Re: Cub Cadet 107 Lift Handle?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
