Re: oops Farmall M model question??
Posted by Wardner on May 16, 2004 at 08:43:18 from (63.159.104.18):
In Reply to: oops Farmall M model question?? posted by dave on May 16, 2004 at 07:08:46:
Your previous post mentioned a H with a two point hitch. That combo did not exist unless a talented farmer built it.
You have now corrected that post stating it was a M with a two point hitch. The same comment applies.
What you probably saw was a M with a three point hitch or a SMTA with a two point hitch. IH did not equip SMTAs with either hitch but the model could be retrofitted easily. $900 for a good running SMTA with a hitch is an excellent price.
Post a Followup
: Re: Re: oops Farmall M model question??
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
