Re: H Bolster Shaft Wearing Top Gear Cover
Posted by randy hall on May 16, 2004 at 12:07:53 from (209.11.236.27):
In Reply to: H Bolster Shaft Wearing Top Gear Cover posted by cheg on May 16, 2004 at 06:29:11:
i just redid the frontend of an h and there is a thick spacer washer under the thrust bearing that was worn thin, you probably need this washer and a new bearing like dave said.
Post a Followup
: Re: Re: H Bolster Shaft Wearing Top Gear Cover
