Re: 856 blowing water out radiator
Posted by steve on May 16, 2004 at 19:43:04 from (152.163.253.103):
In Reply to: 856 blowing water out radiator posted by Larry B. on May 16, 2004 at 15:24:31:
i worked on a 856 about 10 years ago and it was doing exactly what yours is. it turned out the block was cracked about 2 inches from the head surface,about the area where the head bolts end we pressure checked with air pressure through injector hole to figure witch cylender and when we pulled the sleeve the crack in the block was very visible.combustion gases went betwine sleave and block and through crack into cooling system
rn
Post a Followup
: Re: Re: 856 blowing water out radiator
