Re: MTA-Problem
Posted by K.B. on May 17, 2004 at 11:38:15 from (209.163.30.85):
In Reply to: MTA-Problem posted by Ted on May 17, 2004 at 06:04:51:
Are you sure it was from the clutch housing? Did you just shift before it happened? Sometimes as the end of the shifter wears, they get into two gears at once, then you've got broken gears. Start out by removing the inspection cover from the bottom of the clutch housing, not because a clutch problem is likely, but really just because it's easy to remove, a good place to start. If you don't see anything obviosly wrong there, then it's time to drain the rear end and remove the transmission cover.
Post a Followup
: Re: Re: MTA-Problem
