Farmall Tractors Discussion Board
Re: Charlynn pump on pto has leaking seal.
Posted by GeezerMn on October 27, 1999 at 09:39:22 from (216.161.105.79):
In Reply to: Charlynn pump on pto has leaking seal. posted by Rod Hergott on October 25, 1999 at 19:19:09:
After-thoughts----- The info I gave on a previous post applys to a pump with diecast alum.
front housing.If you have a pressed steel housing
there are gaskets at hose connect blocks that hold
hyd.pressure.They may leak.Also seal info.may not apply.To slide seal over keyway & snap ring groove wrap a layer of electrical tape from
bottom to top of shaft & lube.
Post a Followup
: Re: Re: Charlynn pump on pto has leaking seal.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
