Re: pulley pump seal leaking
Posted by Haas on May 17, 2004 at 18:32:34 from (12.65.61.65):
In Reply to: pulley pump seal leaking posted by nickWI on May 17, 2004 at 16:04:18:
Once the three bolts are out, there is nothing else holding the belt pulley drive assembly. It is probably just stuck from years of being there. A little help with a pry bar should break it loose. However, a few other comments. The entire shaft the pulley flange and the retainer flange will come out. The shaft has two bearings on it plus the drive gear on the end. To change the seal, the gear and both bearings (plus I think a spacer) must come off. Best to use a bearing press to take all this apart. Also, the flange with the three bolts does not have a gasket, only metal shims to adjust the gear lash. Make sure you get all those back the same as they were. Cleanliness is very important in installing these shims, as any contamination will result in an oil seep. Good luck!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
