Re: IHC 354 Steering wheel removal
Posted by Allan on May 19, 2004 at 03:39:09 from (148.63.132.164):
In Reply to: IHC 354 Steering wheel removal posted by StewJackson on May 19, 2004 at 02:07:43:
Stew,
Have you tried lightly rapping the puller screw bolt with a hammer while it is under tension?
Pull up on the wheel to keep from damaging anything below.
Just an idea,
Allan
Post a Followup
: Re: Re: IHC 354 Steering wheel removal
