Re: Re: Re: 1940's Farmall H - Replacing Light Swi
Posted by Bob M on May 20, 2004 at 04:25:16 from (165.170.128.66):
In Reply to: Re: Re: 1940's Farmall H - Replacing Light Switch posted by riverbend on May 19, 2004 at 18:00:16:
That's definitely possible! It means the generator is wired up incorrectly.
Sounds like your H has the gen "F" terminal wired to the field resistor on the light switch. Instead the gen "F" terminal should connect to the "FLD" terminal at the regulator.
If you reconnect as above the generator should function properly - presuming the regulator is good of course.
Post a Followup
: Re: Re: Re: Re: 1940's Farmall H - Replacing Light Swi
