Re: Changing H Brake Bands
Posted by jcnc on May 20, 2004 at 13:26:43 from (205.188.116.213):
In Reply to: Changing H Brake Bands posted by Garrison on May 20, 2004 at 06:41:43:
Remove levers and spring from brake cover.
Remove adjustment screw at bottom.
Remove bolts holding cover and remove it.
Remove brake bands.
Remove seal around shaft from differential. (This can be difficult. Be careful to not break the casting)
Replace seal.
Replace brake band (seals and bands are available from the IH dealer).
Put everything back together. I found I didn't need to screw the adjustment screw in very far.The new bands and linings were a tight fit.
Adjust brake pedal as needed.
I hope this helps. I did the brakes on my "H" but it's been a couple of years so I hope I didn't leave out something.
Post a Followup
: Re: Re: Changing H Brake Bands
