Re: Re: Priming live hydraulic pump
Posted by TC on May 22, 2004 at 04:24:41 from (208.0.27.16):
In Reply to: Re: Priming live hydraulic pump posted by Dave in CT on May 21, 2004 at 19:27:04:
a pump from a 300 bolts on in front of the distributor and runs off the timing gear. in order for it to bolt up, you need a timing cover from a 300 as well. it is also recomended to use a timing gear off of a 300. I'm using the belly pump for a resevour. i don't have any pics, but there are pics and other information on this sight from others that have done the same thing.
Post a Followup
: Re: Re: Re: Priming live hydraulic pump
