farmall a
Posted by kevin on May 22, 2004 at 20:14:32 from (66.82.9.40):
I have a farmall model a with a problem. It can best be described as "surging". It will start and run just fine, but under a load the rpm's will surge up and down and you can't catch up to it with the throttle. I have rebuilt the zenith carb to no avail. I don't know where to go next. Any help would be appreciated. Thanks
Post a Followup
: Re: farmall a
