Re: Hydraulic lever on 300 utility
Posted by Wardner on May 23, 2004 at 15:32:57 from (4.138.245.16):
In Reply to: Hydraulic lever on 300 utility posted by Earl in Pa on May 23, 2004 at 15:13:44:
Is there a "D" and a "S" cast into the valve body?
"D" stands for double acting. "S" stands for single acting.
Double acting will give you pressure in both directions of cylinder travel. Single acting gives you pressure in one direction and depends on weight of implement or hitch to run the other direction.
Turn the valve spool to select between "D" or "S". Most spools have flats at the end so that a wrench will fit.
Post a Followup
: Re: Re: Hydraulic lever on 300 utility
