Re: Re: Stupid Question
Posted by CNKS on May 23, 2004 at 18:27:01 from (207.178.96.213):
In Reply to: Re: Stupid Question posted by Jeff In Ontario on May 23, 2004 at 17:33:37:
At the very least: Clean it good, and sand it, and use epoxy primer. The epoxy will act as a sealer and seal the old paint, whatever it is so that it won't lift the new. This will work only if the old paint is in good condition. I know you have already primed the sheet metal, but epoxy would have been best for that too. IH did not use primer, but their paint did not last long either.
Post a Followup
: Re: Re: Re: Stupid Question
