Re: rear tire repair
Posted by Larry on May 24, 2004 at 03:39:35 from (64.12.117.22):
In Reply to: rear tire repair posted by H Fan on May 23, 2004 at 17:36:20:
If you don`t do alot of hard pulling - put a boot in and forget it. If you need traction to pull a plow, disc, etc. - get a new tire.
Post a Followup
: Re: Re: rear tire repair
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
