Re: H wont start with starter.
Posted by Wayne Swenson on May 24, 2004 at 20:12:15 from (66.228.233.180):
In Reply to: H wont start with starter. posted by Dan on May 24, 2004 at 18:28:50:
Sounds like you have battery ignition and when you turn on the lights, the battery voltage gets too low to produce a spark causing the engine to stall.
Your charging system is not doing it's job; check the generator brushes and related parts. Be sure all connections are clean & tight.
As another contributor mentioned, your battery may be failing; have it tested or get a new one.
Post a Followup
: Re: Re: H wont start with starter.
