Re: Re: Looking for Bob M.'s website
Posted by Bob M on May 25, 2004 at 05:30:45 from (165.170.128.66):
In Reply to: Re: Looking for Bob M.'s website posted by Pa. Pete on May 24, 2004 at 19:52:21:
Pete - If your coil is internally ballasted (a so called "12 volt" coil) it doesn't require an external resistor. However if you still have a 6 volt resistor, running it on 12 volts will burn out the points prematurely, also will overheat and ruin the coil after a while. How to tell whether the coil is 6 or 12 volt? Look to see if it's marked "12 volt" on the outside. If not marked, check the current draw with the engine stopped and the switch on. 2 - 3 amps means it's internally ballasted; 4 - 6 amps means you need a ballast resistor. Or simply feel the coil after the engine's run 10 - 15 minutes - if the coil is hot to the touch you need to add a resistor! Regarding your single wire alternator question, these units have a regulator inside.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
