Re: 806 hydraulics
Posted by Old Dutch on May 25, 2004 at 18:16:18 from (66.188.124.254):
In Reply to: 806 hydraulics posted by johna on May 24, 2004 at 19:26:06:
Johna:
It would appear to me if it is lifting one side or the other depending on the location of the leveling device, the problem has to be in the leveler. They are designed to lift both sides at the same time are they not? I believe they are set up to divide the flow evenly to each cylinder so as to raise simultaneously. Hope I helped some.
Post a Followup
: Re: Re: 806 hydraulics
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
