Re: IH 424 Hyd.
Posted by JB on May 25, 2004 at 20:37:57 from (64.10.154.235):
In Reply to: IH 424 Hyd. posted by TDK on May 25, 2004 at 00:30:01:
Hi, like someone else said there is only a screen on the suction line from the hydraulic reservior under the seat. If I remember correctly the suction line is the larger line. There is about a 2 inch piece of rubber hose with 2 pipe clamps on it that joins the pipe coming out of the reservior to the pipe going to the pump. Loosen the clamps and slide the rubber hose towards the front of the trator, then rotate the pipe coming from the reservior so that it will pass the other pipe and pull it out of the reservior. There should be a screen on the end of the pipe.
We would place the tractor on an incline so the front end was much higher than the rear to prevent the hydraulic oil from all running out.
Put some oil on the O ring before reinserting in the reservior.
Be sure to apply parking brake and block wheels if you put tractor on incline to clean filter.
Be careful
JB
Post a Followup
: Re: Re: IH 424 Hyd.
