Farmall Tractors Discussion Board
Re: Re: PROGRESSION OF 1939 DESIGNED IHC TRACTORS THRU 60's
Posted by Harold H on October 28, 1999 at 04:47:02 from (207.244.56.125):
In Reply to: Re: PROGRESSION OF 1939 DESIGNED IHC TRACTORS THRU 60's posted by Rod Hergott on October 27, 1999 at 19:44:09:
Rod,
460 has same size transmission/rear end as H. 560 has same transmission/rear end size as M. As I stated, engine size jumped lines several times.
Harold H
Post a Followup
: Re: Re: Re: PROGRESSION OF 1939 DESIGNED IHC TRACTORS THRU 60's
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
