H 4 mag.
Posted by tiny on May 26, 2004 at 17:32:56 from (24.247.237.122):
third party image
What is the screww on the side of the mag for besides grounding the mag out?
There is a nut behind the screw and when you turn it clockwise the tractor starts sputtering, turn it counter clockwise it smoothes out. It is loose so it will vibrate clockwise after a while and make the tractor sputter.
Post a Followup
: Re: H 4 mag.
