Re: super m timing
Posted by Allan on May 26, 2004 at 17:40:04 from (148.63.132.164):
In Reply to: super m timing posted by freddie williams on May 26, 2004 at 16:00:48:
Hi Freddie,
For what it is worth:
1. Retarded ignition timing will make any engine run hot(er).
2. Timing has absolutely nothing to do with "run on", "after-run" or "dieseling" as I like to call it.
Think about it: when you shut that ignition switch off, there is no more ignition timing; you've just killed it.
So, all that remains is just a hot spinning engine and that fuel, which is still coming in as long as the engine continues to rotate.
Slow your idle speed down and she'll die for you as it should.
Tryin' to help,
Allan
Post a Followup
: Re: Re: super m timing
