Re: super m timing
Posted by Dave S on May 26, 2004 at 17:46:00 from (198.26.126.13):
In Reply to: super m timing posted by freddie williams on May 26, 2004 at 16:00:48:
My H Fire Crator piston and sleeve kit come with a new distributor shaft, weights and springs to change the timing advance. Haven't installed anything yet.
Post a Followup
: Re: Re: super m timing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
