Re: 300 utility backfire
Posted by Bob M on May 27, 2004 at 18:27:41 from (66.67.11.95):
In Reply to: 300 utility backfire posted by dave on May 27, 2004 at 17:38:21:
Dave. These tractors do not have a vacuum advance on the distributor. Consequently they are prone to backfire somewhat when the motor is holding back. This is normal.
However if backfiring is severe check that the ignition timing is not retarded from spec. Also if the centrifugal advance inside the distributor is stuck or the springs are broken they can backfire pretty good - and also lose power/use more gas...
Post a Followup
: Re: Re: 300 utility backfire
