Re: TA rebuild, but not all bad
Posted by rebuilder on May 28, 2004 at 04:33:04 from (216.241.134.229):
In Reply to: TA rebuild, but not all bad posted by Chris Brown on May 27, 2004 at 19:40:22:
Chris;
T.A.'S are not extremely hard to do, but the main thing is to check all bearings and bearing surfaces where needle bearings ride. the needle bearings I replace if I canput an o ring pick into the needles and create a gap. Also use new needles for the planetary gears, no execptions. Lastly I grind all the carriers where the ramp rollers ride to create a smooth surface. However, if your surface looks smooth as a bearing cone surface then you should be fine. I get my parts from several different wholesale suppliers and I.H. If you have trouble getting parts post me back though this site.
Post a Followup
: Re: Re: TA rebuild, but not all bad
