Re: farmall m hub bolts
Posted by junkyard dog on May 28, 2004 at 17:30:20 from (205.231.150.170):
In Reply to: farmall m hub bolts posted by Jamie Stratton on May 28, 2004 at 16:44:35:
they are a rugular 3/4 bolt won't find one with a 1inch head though you have too heat the crap out of the hub where the shoulder of the bolt goes through as well as the clamp with the threads good luck JYD
Post a Followup
: Re: Re: farmall m hub bolts
